I have 3 lights (Power is coming in the first light) that are enter image description hereeach on a single switch (in the same circuit). I want to put the 3 of them on the same switch. I found this helpful diagram but my switch is at the beginning of the circuit. How should I wire it?
  • I take it you mean that power is coming to the location of the switch first when you say "my switch is at the beginning of the circuit" Dec 12 '20 at 23:00
  • Don't look for a diagram for a 3-light circuit, look for a diagram for wiring 1 light where you have power->switch->light. Then extend the wiring to the other lights.
    Dec 13 '20 at 13:06
Here's the set up you need only need to run cable for 3rd light.
