I was trying to replace a GFCI in a bathroom and the cable and wires are pretty black. The GFCI is also pretty burnt.
Do I need to replace the wiring and the GFCI or can I reuse the wire?
Sign up to join this communityI was trying to replace a GFCI in a bathroom and the cable and wires are pretty black. The GFCI is also pretty burnt.
Black is carbon; carbon is relatively conductive compared to clean vinyl or other insulator. So anything black or brown indicates a leak path. As a boy ,I miswired a 440 V box. The real electrician could not clean off the carbon well enough to use it and had to get some new equipment.
Only way to make sure it is ok , is to insulation test the wiring with a megger.Agree with the other statements of arking/sparking being bad.
