10
This water heater was replaced by a plumber 4-5 years ago. Within about a year, all the new connections were rusting/corroding.
Did the plumber not sufficiently tighten the fittings?
Is this perhaps an electrolysis problem?
Notes:
  • Water here is quite hard
  • Pipes in the house are a mix of copper, galvanized, and pex.
inlet
inlet valve
outlet
  • If nothing else, check that the 1/4 turn stop valve is still effective, The outer corrosion may mirror what's going on in there too.
    – Tim
    Commented Dec 9, 2020 at 18:51
  • Your valve looks like mine did, just before it broke off in my hand when I went to turn it off. If you haven't already, I'd suggest turning of the water elsewhere, relieving the pressure, and cranking hard on this valve a few times to check to see if it's compromised.
    – LShaver
    Commented Feb 15, 2021 at 17:20
  • condensation and oxygen when the pipe is not fully protected from it does it make sense to you Commented Aug 31, 2023 at 18:47
5 Answers 5
21
Looks like minor leaks, compounded by mixing galvanized pipe and copper/bronze valve without using dielectric couplings between dissimilar metals.
Honestly, any plumber installing NEW galvanized pipes (rather than just making repairs to existing) in the past 5 years is doubtful. If you really want threaded pipe, stainless is available and lead-free, which galvanized iron pipe is not.
    Brass is compatible with both copper and galvanized steel so as long as copper wasn't attached to steel then there shouldn't be a need for dielectric couplings.
    – MonkeyZeus
    Commented Dec 9, 2020 at 13:40
9
100% galvanic corrosion, "Pipes in the house are a mix of copper, galvanized, and pex", different metals cause corrosion. You should stick to one type of metal in your pipes or use pex.
**Note that galvanized means iron/metal with sacrificial coating usually zinc in this case.
See https://galvanizeit.org/hot-dip-galvanizing/how-long-does-hdg-last/in-contact-with-other-metals for more information,
I want you to consider that if you have old iron pipes with copper , the iron will flake off internally due to age and cause corrosion spots on copper and that is how you get pin hole leaks inside your pipes , check your aerator in your faucet for such things and flush your pipe when you have this corrected.
Yes, you have small leaks causing rust. See how the rust practically flows like water in this picture?
Overall, galvanized pipe should be avoided nowadays as there are much better options such as pex. Ever seen the inside of an in-use galvanized pipe? It looks exactly like what your seeing on the outside.
I would not try tightening it further as you will introduce new problems. You can leave it be if the leaks aren't pooling anywhere or get things re-piped with plumbing that doesn't have this issue.
You can try galvanized steel again but just make sure all the connections are properly sealed with tape or dope and are screwed on tight enough.
The galvanized pipe is what is corroding and rusting. As noted,there may be other factors at play here like leaky connections but the galvanized pipe is definitely a problem.
You should re-plumb with cooper pipe, or pex, and make sure to use a Dielectric Nipple on the inlet and outlet of the water heater.
The zinc was cut off when the pipe was threaded and most rust is from bare steel threads . There may be a bare steel close nipple in there also. So the zinc/galvanized is pretty much doing it's job where it was not removed. The moisture is from condensation not leakage. If you replace it with new galvanized ( which contains no more than a trace of lead) the labor will be costly. Same high cost for stainless and copper. Or ,you could wire brush off the rust and put on some grease for very low cost ; and hope there will not be much more corrosion. I doubt there is significant metal loss . mostly it looks bad.
    I must correct myself and say that there could be 1.4 % Pb in RECYCLEC zinc ( ASTM B 960 ). . But prime western zinc ( ASTM B 6 ) will be much lower Pb ,but you have to buy the spec to find out the number. As luck would have it , my first employer produced recycled zinc . The actual Pb was much lower than the 1.4 % max because most of our zinc converted to oxide which went into rubber ., And rubber makers do not like Pb. Commented Dec 8, 2020 at 21:58
