I have bought a smart outlet which has only three wires (Green, White, Black), however, the wiring available in my condo has four wires. I would appreciate it if you could help me in properly setting up the outlet.
1Can you post a photo that looks into the back of the outlet box please?– ThreePhaseEelDec 8, 2020 at 0:00
1Eh, Canada and US wire color coding isn't that different -- what you have is a conduit job, which lets the electrician pull out the fancy colors to suit, more or less ;)– ThreePhaseEelDec 8, 2020 at 0:28
1Also, is the tab on the hot side of the existing receptacle intact, or broken off?– ThreePhaseEelDec 8, 2020 at 0:29
1Which half of the receptacle is controlled by the existing switch(es)? I'm guessing it's the top, but I'm not 100% sure– ThreePhaseEelDec 8, 2020 at 1:03
1Top half is controlled by a switch.– X_Novichok_XDec 8, 2020 at 1:08
Show 10 more comments
