Bosch Dishwasher SHU43C02UC/17
I noticed that the filter screen was raised at the far left corner. So took it the rest of the way off and cleaned out round filter as long as I was in there.
Then replaced and fastened filter and screen.
Later when I ran the dishwasher I could hear a noise while it was running. Dishes came out clean. But when I ran later, I had very low pressure. Some pressure out the bottom spouts but nothing out of the top.
I still hear humming sound when running but much lower.
Dishwasher pumps out water fine...just no washing pressure.
Any ideas/suggestions?
    You probably dislodged some material that now resides in the upper sprayer plumbing. You'll have to clean that out.
    Nov 30 '20 at 21:16
  • That crossed my mind, but the lower sprayer pressure is not enough to even make it spin. I took the sprayer off and ran a cycle with the door open. Pressure coming from pump is very low. But at end of cycle water exits adequately.
    – Mr. D
    Nov 30 '20 at 21:45
  • Mr D it looks like you answered your question, chech the pump possibly replace or clean the food particles out of the intake.
    Nov 30 '20 at 21:52
  • So as I think about the whole situation. The filter screen was raised due to a small rib bone that somehow got underneath its edge. So I am thinking that there must have been a piece of cartiledge or bone that was under it and therefore released and would have made it by the catch filter since it was out while I adjusted the tray. With that in mind and the resulting change in the function of the dishwasher...would you say that I damaged the impellor? or circulation pump or could it just be stuck in there and I might fix it by taking apart and cleaning out?
    – Mr. D
    Dec 1 '20 at 16:57
  • Or, based on events, is it probably broken? Trying to avoid needless labor. May just go get a new one.
    – Mr. D
    Dec 1 '20 at 17:36
