After 3 years the Faucet just started cutting out when trying to get to a higher pressure. I can only go to about 1/3 of max. I thought it might be the 3 way valve as most are plastic now. When to HD and got a new one put it back together and BAM, same thing. I saw a thread here that suggested it was a plugged aerator. So I took the nozzle apart and it was clean, except for the out side (you know).
I know out here in Calif they have all kinds of dumb regulations on faucet and shower flow. But those are usually easy to remove.
So what causes a brand new valve to cut out? Is there some other kind of stupid stuff in the faucet?
