The "spring" for this mepla hinge has broken. It's shown left of the hinge in this photo, "appearing" to be unbroken. Is there anyplace i can get new spring?
It's unlikely that you can get a new spring, but the good news is that you'll be able to find a new euro cup hinge. Take the entire unit (including the base plate that's still attached to the cabinet) to a cabinetry supplier. If you don't have one, refer to the Blum catalog and try to match the relevant offsets. (Hint: this is hard, as there are a zillion different combinations available.) Replace all the hinges on the door -- don't mix and match.
Try taking the hinge to a home store like Home Depot or Lowe's. I just replaced a number of similar hinges and they have a huge selection. You'll need to buy the entire hinge but they are not expensive.
FWIW, my home derpo/lowes have terrible selections of hinges. The OP might get lucky, but I wouldn't bet on it. My cabinet/door place has an entire aisle devoted to euro hinges. Nov 29, 2020 at 22:01
