We're building some shelves to fit in an alcove next to our fireplace, and so we built 4 frames using 1x2s for the front and back of the frame and 2x2s as the ladder support in the middle (each spaced about 12" apart from each other). Each shelf is 49.5" long and 21" deep. I drew a SketchUp model to better visualize it.
Sketchup model of shelf frame
We've installed it on the wall by screwing the back and two sides into the wall studs (image of installation below). Our next step is to install 1/4" plywood to the top/bottom.
Our main worry at this point is with the sag in the middle. Because our shelf is so deep (21"), we're afraid that over time it will warp and sag. We've thought of a few ways to fix this, but we don't know which way is the best. We've thought of installing some sort of brackets on the inside and/or outside of the frame, or just installing a long 2x2 to the bottom of the shelf towards the front to help prevent sagging. We considered adding braces to the bottom, but we are trying to have the floating shelf aesthetic, and adding braces (metal or wood) would eliminate the "floating" aspect to it. Are there any suggestions as to what we can do to prevent sagging in the middle while keeping it as close to this look as possible?
  • 4
    I don't think you're going to see much sag. If you're worried, increase the shelf thickness to 1/2" or 5/8".
    – SteveSh
    Nov 29, 2020 at 20:34
  • Agree that sag shouldn't be a problem, assuming you glue and screw the plywood skins. If in the future it does sag, you can attach a 3/4"x2" nosing to the front. (Again, glue and screw.) Nov 29, 2020 at 20:37
    It all depends on what you plan to put on the shelf. I think upgrading the front piece to a 2x2 will help increase the capacity somewhat and be minimal work at this point.
    – bigchief
    Nov 29, 2020 at 20:47
  • When we put pressure in the middle front of the shelf, it starts to flex and bend downwards, which is why we are worried about sag in the future. I don't think we plan to put very heavy things on it, but the shelves will likely include the stereo amplifier you see in the photo and some potted plants (~ 10-15 lbs)
    – Sean M
    Nov 29, 2020 at 22:48
    You can get an idea of the sag: woodbin.com/calcs/sagulator. It seems acceptable - but gluing the front of the plywood and/or doubling the front (using a 2x2 or gluing another 1x2) would help. If the back is attached, the stress will be on the front of the frame (where the 2x2 would be more useful than on the ladder).
    – ptyx
    Nov 30, 2020 at 18:15
4 Answers 4
Assuming that the sag would only be in the middle of the front edge of the shelf you will have to add something stronger than the along the front edge length. A 1x2 on edge (actual size 1.5" vertical and 0.75" thick just is not strong enough to prevent significant sag.
Since you will already have the raw edges of the 0.25" plywood showing along the front edge an added additional piece of wood would hide those edges and trim things up nicely.
For the stronger wood piece I would suggest adding a piece of hardwood like oak such that its upper edge is even with the top plywood. The bigger the vertical dimension that this piece of wood has the stronger it will be. Over a 49.5" length I would, based upon practical experience, suggest that the oak piece be 0.75" thick with a vertical height of about 3" actual. You would still not want to climb or sit on the shelves but they will sag way way less than your current 1x2.
If you have the plywood cladding installed so that it does not overhang the edge of the 1x2 you can use the yellow colored wood workers glue to secure the oak piece on place. A series of five or six clamps will permit clamping the piece in place. (Recommendation is to not install the lower plywood cladding till after the gluing is complete so that clamping the oak piece to the 1x2 is easy from the lower edge).
  • Okay, that sounds like a good idea. The plywood has not been installed yet, what you see in the photo is the plywood just laying flat on top of the shelf. We kind of want to keep the ultimate depth at around 21", would it be better to replace the front 1x2 entirely with the oak hardwood you recommended? Alternatively, we can trim the bars in the middle by 0.75" to accomodate for the oak piece thickness.
    – Sean M
    Nov 29, 2020 at 22:39
  • Also, none of the frame has been glued together, it's all screwed together. I'm more than willing to take it down and glue it all together, but it would be difficult because the alcove isn't quite square. It's very slightly wider at the front than at the back, so we screwed the rear and sides to the wall independently and then attached the front piece afterwards.
    – Sean M
    Nov 29, 2020 at 22:40
    @SeanM - The screwed together frame is just fine. Just make sure to follow the other answer suggestion to glue the 1/4" plywood skins to the pine frames that you already made. As far as the added oak front piece that I suggest please just glue that to your already existing 1x2 leaving the top edge to conceal the edge of the plywood; It will look much much better that way. The added depth added to the shelf by applying the added 3/4" oak to the front is rather trivial up against your current depth and you have plenty of additional alcove wall space left in front of the shelves anyway.
    – Michael Karas
    Nov 29, 2020 at 23:00
    Why put the additional wood on the top of the shelf when that part is in compression and neglect the bottom that's in tension. Adding thickness (i.e. increasing the distance between top surface to bottom surface - with the same plywood) to the shelf will make it stiffer.
    – D Duck
    Nov 30, 2020 at 13:07
  • @DeDuck - Not on top but even with the edge to hide the raw edge of the plywood.
    – Michael Karas
    Nov 30, 2020 at 16:52
The design presented lends itself well to a 'stressed skin' design, or 'sandwich panel' (jum!). This design is common in aircraft construction.
You probably tested the shelves with the plywood loosely in place. When you do this, you load the plywood and frame in bending, which individually are quite weak.
However, things are very different if you properly attach plywood to the top and bottom of the frame. With properly, I mean that there may not be any sliding between the plywood and frame, so glued, screwed, dowel pinned and/or nailed along the entire perimeter and any internal bracing.
Now, when the shelves are loaded, the bottom plywood is loaded in tension and the top in compression. The resulting design will be very stiff in bending, and because of the closed box construction, it will even be relatively stiff in torsion, too.
    +1 with this exception: "glued or screwed" -> "glued and screwed"
    Nov 30, 2020 at 16:23
  • @FreeMan I imagine they may want to avoid screws for aesthetics (although I guess all screw connections could be made from the bottom). But really, any method of transferring shear works, perhaps small dowel pins.
    – Sanchises
    Nov 30, 2020 at 16:45
  • @Sanchises If it's plywood, I assume they'll be painting it. So any screw heads could be easily hidden that way.
    – TylerH
    Nov 30, 2020 at 17:05
  • Or you just buy a door blank, and cut it down to size.
    – Joe
    Nov 30, 2020 at 21:01
Make sure both pieces of plywood is completely bonded to every point of the frame, the 1x2s and the 2x2s with wood glue and screws. The plywood will help prevent flexing which is what allows sagging. I don't believe 1/4 plywood will work on this one unless you don't put heavy stuff on the shelf.
Unfortunately a lot of people try to imitate metal furniture designs with wood. You won't get that "thin graceful floating aesthetic look" (the Rivendell Fairy Furniture look I like to call it) without using steel. JRR Token used metal in his Middle Earth designs which was sort of funny since his world had steel very rare for use in weapons. None of his battle towers and seige weapons (catapults, etc.) used steel but all the furniture the Elves used did. (since there is not a wood with the strength capable of those designs)
  • So, a thicker plywood may help with the flexing? Also, none of the frame is glued together, and we're considering taking it down to glue it to make it stronger. It's a bit difficult because the alcove isn't perfectly square like we had hoped (it's slightly wider towards the front), so we had to push on the outside bars outward a little bit to attach to the wall. I don't know if gluing it together would allow us to fit the frame against the wall.
    – Sean M
    Nov 29, 2020 at 22:45
  • Make the core of the shelf thicker - increase the distance between top ply and bottom skin. Bonding to frame to ply is a good idea. Ply on the bottom can be a skin as it's in tension, and the top thicker.
    – D Duck
    Nov 30, 2020 at 13:12
  • It is very common for walls in a house to not be perfectly square. I think you are wise to just start over on this one. Build the shelf out of the alcove as thick as the narrowest part of the alcove and bolt in some small wood blocks to the wall the shelf can rest on. One of these days you are going to want to paint the alcove. Also that way if you are dissatisfied with the shelf you can replace it with a different one. Or you can put in a glass shelf or some such. Dec 3, 2020 at 9:18
Your shelves will only be as strong as your weakest part, and right now that's your 1x2 front.
If you are really that concerned, double up your frame on the outside edge. Or add or replace with a clear (no knots) 2x4 instead of an additional 1x2. Even a clear 1x4 will be much stronger than a 1x2. Using clear boards are generally stronger than knotty. The tiny knots you currently have probably aren't a problem, but larger ones can seriously compromise structural integrity.
You can also cut a strip of the plywood to face the shelves. the current 1/4" isn't much, but if you glue it on, it'll add quite a bit of rigidity. Simply screwing it on will likely just break the plywood if there's enough weight to actually bend the shelf, since the weight will really only be applied to the plywood at the screws and so the plywood will move at a different rate than the shelf, essentially making it more rigid than the shelf. Getting a small sheet of 1/2" would be much better and you won't lose too much more space to the shelf. This would also be applied with glue and screws. You could clamp it and leave off the screws, leaving the front smooth. Good wood glue is stronger than wood.
As others have said, fully boxing the shelves will help, especially if you glue on the plywood, but even that only helps so much. What you need to consider is what you want your shelves to hold. Is it just a bunch of light Christmas ornaments, is it heavy home theater electronics, what about a mixture of heavy and light sporting gear, or is someone going to end up sitting on it?
I see what looks like an audio receiver sitting on a shelf at the moment, but I'm assuming there's going to be other uses of the shelves, too. I've had receivers that were light at maybe 10lbs and others that felt like they were 50lbs. Also, are there speakers going to be on the shelf? The size and type can cause different issues. Heavy ones can add more weight than the shelf is capable of handling. A subwoofer could cause the shelf or plywood to buzz annoyingly, or it could add vibrational stress that causes it to fail sooner. And a good subwoofer is normally pretty heavy.
There's a lot to think about when building a shelf like this. Even as simple as it seems, you are already seeing the complexity of what it take to figure out what you support with the shelf.
“Any idiot can build a bridge that stands, but it takes an engineer to build a bridge that barely stands.”
  • Unknown
https://www.workflowmax.com/blog/101-engineering-quotes-from-the-minds-of-innovators
Believe me, I'm that idiot in a lot of things, since I just over-build everything. What the above phrase means is that it takes a lot of math, use consideration, experience, and more to figure out how to build something that meets specifications exactly, instead of being overly strong or even fail completely. And yes, adding a 2x4 to the front of your shelf is probably "over engineering" it, but it nearly guarantees your shelf will remain strong "through the ages" as well as for most things you want to put on it.
    The only benefit to building something that just meets specs exactly is cost saving and when you are building stuff for yourself you are already saving so much there's no point in cost savings you also have no economy of scale to get a multiplier effect on. Saving a dollar on a shelf matters when you are building 100,000 of them for sale at the big box store. It's meaningless when you are just building 1. The furniture makers found it to be more profitable to brainwash the public into liking spindly furniture that fails early and often....<eyeroll> Dec 3, 2020 at 9:23
