I picked up a Yamaha htr-3064 from good will for $14.99. Seamed like quite the steal. Back of the unit says it can take 6 or 8ohms speakers. I had also picked up a pair of Tandy Realistic tower speakers, said 8ohms max. Looked good, mesh was intact and cones were clean. So i hooked them up to the bannana plugs and i had no sound, no crackle or pop. After the fact i opened the speakers up and 1 had noticable charing on a wire going to the cone and no continuity. I then hooked my multimeter to the outputs on the receiver and could hear the music theme from my Playstation. The volume is at -33.5 to hear the start of the beat and around -29 for vocals and other instruments. With distortion and buzzing of the multimeter of course.
If i hear music from my multimeter would that mean my reciever is fine?
What would be the proper way to test that the reciever is not the one to blame?
