I have a large ceramic plate that I wanted to hang in my kitchen. It is 22" in diameter and it's circular. It weighs almost 15 lbs. Is this a possibility? I don't see any plate hangers out on the internet that can accommodate the circumference and handle the weight. Any suggestions?
Get drywall anchors that are the plastic kind that screw into the drywall. Home Depot sells these. Then when the anchor is in thread in a wood screw and hang the plate off that. Twist-n-lock for example is one of that style. Google "Brass Plate Hanger Displays Plates on Wall Size 5 to image" off etsy for what you need for the plate itself.
You could put it on a plate shelf - a shelf that has a groove in it that the edge of the plate sits in to prevent it from sliding off.
