I am looking to add a new light and the best access I have is from an adjacent room's light fitting. This ceiling rose has 3 supply lines, which I assume is a supply in, supply out and a spur.
Is it OK to add another spur from this fitting?
I am also unsure where this spur goes as the other light fittings also have 2-3 supply cables. How would I find out which of these 3 supply lines are the in & out? Is it a matter of disconnecting 1 and seeing which lights are not switching on?
    Based on terminology, I suspect you are in UK, or at least not in USA/Canada. That may be relevant to determining proper wiring. So where are you? Nov 26, 2020 at 15:03
    I am in the UK.
    – IamOnStage
    Nov 26, 2020 at 16:43
  • I don't believe there's a "number of spurs" rule, but you'll hit a practical limit based on other rules, such as box fill, which will limit the number of wires or cables you can terminate in the box. Nov 26, 2020 at 18:12
