I am replacing the tub drain (chrome to bronze). I was wondering if I should use plumbers tape on the drain, or is the putty enough?
EDIT: Thank you for your responses. I am changing the drain only. I guess a better question is, should I use plumbers tape between the drain and drain shoe? I know I should use the putty on the edge of the drain but someone told me to use plumbers tape on the threads. I just changed to whole drain shoe and I'm afraid to mess it up by doing it wrong.
Second edit: thanks again for all your responses. It seems the general consensus is that I do not need tape. The shoe is pvc and the drain is bronze.
