The psi on the main Mobile Home Park side is 3
This is before the from to 1/2" pipe leading into my homes main.
The old pipe is galvanized, 3/4 to 1/2" I believe.
In repiping all the water lines to 2 baths 2 toilets 2 kitchen sinks & washer - What would be the the best pipe size solution to get the most water pressure? Thank you in advance.
