Our toilet flush button is stuck down, and the mechanism on the back doesn't appear to be attached properly.
It's a cable pull system.
Any ideas how it's supposed to be attached?
Sign up to join this communityOur toilet flush button is stuck down, and the mechanism on the back doesn't appear to be attached properly.
I have fixed it.
I pulled the blue plastic section away from the bottom of the threaded section. The 2 plastic parts of the flush button sprung back up, and I clipped the blue section back onto the base of the threaded section. I will add pictures later.
