I need to know which insulation I need for my 20x12 metal shed. I am making it into a pool house. Bathroom, sink, bed. Is made of 2x4s, and plywood floor on beam, sheet metal siding, aluminum type doors, 2 small windows.
I live in north Texas, summer can be over 100 degrees and some winters 10 degrees for a few days.
Am putting in ductless air/heat unit. Using Lifeproof Luxury vinyl plank flooring.
Studs are mostly 22 in apart, some 18 and 30 inches apart. Ceiling is studs and sheet metal also.
Also, can I add this before my electrician and plumber get started? Or wait.? on a budget, need cheapest solution, but do NOT want to deal with roll fiberglass insulation.
Thank you
