I want to add a couple of outlets from a generator to inside of the house to avoid having extension cords running through the door when the power is out. Similarly to this product.
I’ve got a small portable generator with a 30a L5-30r plug on it. I’ve ordered a L5-30r inlet box plug and 25ft cord to connect generator to house.
My plan is to get some 10/2 wire. 3/4” conduit to run the 10ga into the house to a pair of receptacles.
The generator is fused @ 30a. But the receptacles aren’t rated for 30a. I’m thinking I should run 2x 20a GFCIs to protect the outlets from being overloaded. It’s just for emergency power, fridge, sump, a light or 2 etc.
Is this correct? I was told I should fuse it separately. Do I need a subpanel?
