I'm going to have a new house built, and I want to have roughed-in plumbing in one room for a small kitchen. I need some help choosing a location to tell the builder. I won't be shopping for cabinets or fixtures until some time in the future, long after I have to finalize the construction plans.
I want the pipes to be in a certain interior wall that's 8 feet wide, but I'm not sure how far the pipes should be from the corner of the room. Is there a standard or rule-of-thumb to follow in the US? Is there a reasonable place to put the rough-in plumbing so that I can easily choose a cabinet later that would work with the pipe location?
    No. The pipes go where the fixtures go. Either finish your layout or leave them stubbed in a wall such that they can be easily extended later.
    Commented Nov 19, 2020 at 20:17
    This will totally depend on your final design. Either that, or your final design will have to accommodate the location of your rough-ins. You may lose some cabinet space by running plumbing horizontally through the backs of the cabinets to get them where you need them. Or, leave the wall unfinished with plumbing terminated in the wall. Then you can do the stubouts and finish later when you know where you need 'em. In the meantime, there's probably not much we can do to help you with this one.
    Commented Nov 19, 2020 at 21:36
Production cabinets are made in standard sizes. If you can make some general decisions about what the future kitchen layout might look like then you can forecast reasonable locations for the plumbing.
First is to decide the shape of the future kitchen. Would it be a single-wall layout, L shape, U shape, peninsula..?
In the US kitchen base cabinets are generally offered in 3-inch increments from 9 to 42 inches wide. Drawer stacks are commonly 15 or 18 inches but sometimes as narrow as 12 or as wide as 21 or 24. Ordinary box cabinets are probably most commonly 18-36 inches wide. A full size sink would usually sit above a 36 inch sink base, but because this is a secondary kitchen space may be tight and you might plan for something narrower.
You've mentioned that the cabinetry would run along an 8 foot long wall and is near a corner. Because it's a small kitchen a narrow sink of 30 inches or less may be appropriate/proportionate. My personal thought is that a sink at either end of the 8 feet would be unpleasant to use so plan on the sink base being the second cabinet from either end.
Assuming a one-wall layout I suggest the 8 foot space be divided into four cabinets: 27 inch, 30 inch sink base, 24 inch, 15 inch drawer stack. There are only a few ways to arrange these. I'd put the 27 inch in the corner and the 30 inch sink base beside it. Then the sink would be centered about 42 inches from the corner and the plumbing could be roughed in near there. You'd still have some flexibility to go 3 inches wider or narrower with that first cabinet as well as with the sink base.
