The switches on a couple of range elements don't work well anymore. Sometimes the burner will suddenly go on full heat while the switch is set to low or intermediate heat.
Is it possible to safely repair the switches, eg. with some alcohol or contact cleaner, or must they be replaced?
Switch model numbers: 3148954, 3148952
Range: Whirlpool YRF263LXTQ0
