I have lost power to my exterior outlets. I have gone through the house resetting GFCI outlets in the kitchen, garage and bathrooms with no luck. I also looked and found no GFCI outlets outside. I reset all GFCI breakers on panel with no success. Inspection of the crawl space and found no outlets.
The house was built in 2014 so there should be a reset somewhere. Any suggestions on what to try next?
Reset
button won't help much if the outlet itself isn't actually working. I'm not 100% certain, but I believe that if the GFCI circuitry has failed, it will cause power to the outlet itself and downstream LOAD side outlets to be off as a protective measure. – FreeMan Nov 17 '20 at 19:12
