I just bought my first house and I am trying to update some light fixtures in my kitchen. I’m also fairly new to this DIY stuff, so keep that in mind if I’m not using the correct terminology.
When I tried installing the new fixture, I couldn’t get the mount screwed in properly because the junction box blocks the mounting screw from getting in deep. Noting that the junction box is old and damaged, I thought it would be best to just replace the junction box entirely, using an “old work” junction box.
So working the existing junction box, which seems to be made up of particle board, I was able to remove two screws that were bracketed (see the blue arrows) that I thought were holding the box up, but when I attempted to pull the junction box down it wouldn’t give. I then noticed that there are two nails holding the box up as well (see the red arrows), which I can only guess means they are nailed to a joist.
Is there a way to remove this junction box without having to get up in the attic?
