I've assembled this bed frame and am not sure how to make it sturdy enough for use.
I have this 100+ year-old Italian bed frame that I've inherited from my parents. They used it for decades and it felt safe and sturdy growing up. Unfortunately they can't remember much about how it was assembled and I haven't been able to find any other info about the bed.
The construction is straightforward: the left/right sides have notches that fit into recesses in the posters flanking the front and rear sides of the frame; each notch is paired with a metal bolt that pushes into a hole next to the notched recess; the top is a single piece with holes at each corner which the four posters slot into.
I can get the notches to fit flush with the posters if I push hard enough, but the whole bed is shaky and comes loose easily when moved. There's nothing holding the pieces together besides the slightly loose notches and bolts. I was hoping the top piece would stabilize it but it did not help much. The remaining parts are particle boards and slats that sit along the shelves on the left/right sides – could placing these and adding the mattress make the difference somehow with the downwards force?
Besides specific solutions, I'm also interested in knowing how to seek expert help on safely assembling this (I live in Toronto if that's relevant). I also wonder if there are ways to reinforce it – like adding ratchet straps around the circumference until I can get it sturdy enough through other means.
