I have an unfinished electrical project I inherited that I want to complete, I just wanted to check and make sure the wiring diagram I've fuddled together below will work. I want to run power through a switch to a light, but continue the circuit over to an outlet receptacle.
The wires have already been run to the boxes, so I'm trying to piece together what my predecessor's plans were.
Am I doing this right?
hashed up diagram of light on a circuit
You have it right. I'm assuming you don't want the outlet to be switched. If you run 12/2 as indicated you can make it either a 15amp or 20amp circuit. With 14/2 it can only be 15amp. If the outlet is in a bathroom or kitchen it must be 20 amp and must be GFCI protected.
  • Note, too, that the ground wire squiggle in the light fixture box should be connected to the box if it's metal and/or to the fixture itself.
    Nov 16 '20 at 18:59
  • @HoneyDo: Thanks, yes, I don't want the outlet to be switched, just to have power. The cable is 12/2. The outlets are in a simple shed outbuilding, nothing fancy like a bathroom or kitchen. Thanks for the help!
    – Cabin DIY
    Nov 16 '20 at 19:09
  • If in a shed you might want to check local codes on amperage required and the need for GFCI protection. Either way I would suggest you run 12/2 and 20amp circuit as well as add a GFCI for a shed.
    – HoneyDo
    Nov 16 '20 at 19:33
Colored tape is your very best friend. Let's re-color wires for purpose:
  • White for neutral (required by Code anyway)
  • Black for always-hot
  • Red for switched-hot as a lamp would use.
