I am not a technical person and I am wondering what are these two things in my basement?
  • I think one of them is the water input (with meter) for my house
  • the second one coming from the ground is for the wastewater output
I am wondering can they be used to add a full bathroom in my basement? the reason I am asking is I contacted a contractor on the phone and he gave me two prices based on whether he needs to dig the concrete foundation to connect the wastewater.
  • It's really hard to tell - is the clean-out (the thing on the floor) recessed several inches down, or is the carpet just cut oddly there?
    Nov 16 '20 at 13:44
  • It's not recessed. It's protruding at a 45 degree angle away from the wall. My guess is that the sewer exits the basement perpendicular there.
    Dec 16 '20 at 13:24
One is a water meter on your main supply that can be read remotely.
The other looks like a drain access plug in case you ever need to run a snake down the pipe.
    "drain access plug" is also called a clean-out.
    Nov 16 '20 at 13:43
    Right, and neither are facilities for a future bathroom. Both must be maintained more or less as they are.
    Dec 16 '20 at 13:23
