On my toilets, both fill tubes are connected to the OUTSIDE of the overflow tubes, so the stream of water is going directly to the tank.
I went ahead and directed the stream to now go into the overflow tube.
Will this help the performance of the toilets now?
  • You have two fill tubes?
    – Alaska Man
    Commented Nov 16, 2020 at 0:59
Yes. That's how it's supposed to be.
You have water coming out by the tube which has the on/off mechanism and a small flexible pipe that is expected to send water inside the overflow tube to refill the bowl. Without that, the bowl is not likely to refill much, actually.
I uploaded a video on YouTube to show it in action.
    ...I think you mean bowl, not tank. Or pan, not cistern for our cross-ponders.
    Commented Nov 15, 2020 at 21:26
  • @Ecnerwal Correct! I made a quick edit. Thank you. Commented Nov 15, 2020 at 21:30
