A club at uni has this great big old table. (about 1220mm by 2420mm).
The club in question is the gaming club, so pen and paper RPGs, card games, boardgames, warhammer. fairly rarely models are assembled on it, so it it will get a bit of glue and paint, and maybe some knife work done on it. It also gets desktop computers put on it occasionally when the computer club has a LAN.
Biggest concerns are it getting dirty - greasy fingers, chips, soft drink spills,
and it being flat. It must be flat so dice can be rolled. (which makes planks kinda bad).
It was made by I don't know who over 20 years ago. The legs and framework are great, but the table top is chipboard which has become all flaky and bad. Someone decided to sand it down - which of course only made it worse. They wanted to take a wire brush angle grinder to it but I really think they are leaping from bad idea to a worse one.
The reason we can't simply replace the table top is that it was glued to the framework. With a lot of work it could be pried off (and a wire brush might come in handy then.)
But as a easier solution I thought we could just screw something on top of it. Leave the chip board in place, and put something over the top.
I'm not super experienced, done a little bit of stuff before. Here is what I'm considering:
3mm MDF sheet
- Pro: very cheap - just replace it when it gets ratty
- Con: Scratch, dies to water
3mm Masonite
I've never worked with the stuff much, but as I understand it:- Pro: Tougher than MDF
- Con: Similar vulnerability to water
3mm Tempered Masonite
I've never worked with this either, but as I understand it:- Pro: Really tough, and water-resistant
- Con: Very hard to get.
3 Ply
- Pro: Not so vulnerable to water
- Con: cracks and splinters
Pine planks
- Pro: Not a particle board, can be worked with sanded etc.
- Con: Comparatively expensive, require a lot more work
Are there options I haven't considered? The goal is to have something I can do in a afternoon, for somewhere under $100.
EDIT: I ended up using Tempered Masonite.
