I have discovered a small leak below my shower base. When I slide some paper towels below the shower, and have the water run for 5 minutes, I see around 5 drops of water, probably coming from a hole in the evacuation pipe.
Two questions :
  1. How necessary is it to fix this? I have tiles below the shower
  2. If I need to fix this, is there a way to put some product inside the evacuation hole that would end up fixing the hole in the pipe?
  3. If not, and I need to remove the shower base to plug the hole, what is the right method to break the cement-joint to lift the shower base?
leak 1
leak 2
  • Why do you suspect a hole in the drain pipe? Can you see it? Did something happen that might have caused a hole?
    – jwh20
    Nov 12, 2020 at 11:53
  • How were the several sheets in the 2nd pic placed? The 1st pic seems to only show 1 sheet. Are you certain that this isn't splash from the shower itself? Is there any sign of water leaking/damage when looking from below (presuming some accessibility to to a basement, crawlspace, floor below)?
    Nov 12, 2020 at 12:41
  • Yes, some builders just removed it and reinstalled it. They were fairly imcompetent. I ended up unscrewing the drain hole, and confirmed there was water underneath. However I am not sure it is from the drain pipe itself or maybe the joint between the drain hole and the shower base.
    – DevShark
    Nov 12, 2020 at 12:43
