I am installing zone valves but want to isolate each loop with ball valves. can I use regular plumbing ball valves for this. Max temp would be 180 F.
    Look at product specs. Most are rated at 200F or higher. Many are 400.
    Commented Nov 11, 2020 at 22:05
  • Commonly metal + teflon (PTFE) so temperature limits are quite high, indeed.
    Commented Nov 11, 2020 at 22:12
You're fine
Ordinary WOG (water, oil, gas) rated, metal-bodied ball valves are going to be rated for hydronic temperatures and beyond; if you want to make extra sure, you can check the specifications of the valve you're looking at for a WSP (Working Steam Pressure) rating, which a typical ball valve (using the Watts LFFBV as an example) will have as well. (Obviously, a plastic-bodied valve is going to have a much lower working temperature rating, and no WSP rating for that matter.)
  • So then is the only reason the handles may be blue or red is to help you identify a hot or cold valve when it's installed?
    – SteveSh
    Commented Nov 12, 2020 at 0:52
  • @SteveSh -- for bog-standard metal-body valves, yeah (many are other colors, I know most of the ones in my house have yellow handles for instance) Commented Nov 12, 2020 at 1:02
