I need to unscrew a screw that I can't access frontally.
How can I do it?
Googling a bit I was thinking of a Torque Wrench, do you think it's the right choice?
    A picture would help. I remove screws on the back side of things all the time. I don’t see how a torque wrench would be any different than any other wrench.
    Nov 10, 2020 at 15:53
  • what exactly are you trying to do?
    – jsotola
    Nov 10, 2020 at 16:06
  • Do you mean you can get to the front but don't have enough room for even a really short screwdriver? If so, what kind of screw head? If not, which part of the screw do you see? Pictures might help.
    – Olivier
    Nov 10, 2020 at 16:07
  • I found my answer.. diy.stackexchange.com/questions/21400/… Nov 10, 2020 at 16:07
  • Screwing/unscrewing from behind can be just as enjoyable. Just make sure you are in the right slot.
    – DMoore
    Nov 10, 2020 at 16:58
Use an angled (or offset*) screw driver:
Image courtesy of chelseaclockwallpaper.blogspot.com. First reasonably small image I found for what I was after
There are also ratcheting right-angle screwdrivers such as:
Image courtesy of harborfreight.com
If you don't have enough room for even that, use pliers to grip the head. You might use locking pliers (ViceGrip™ is one brand name) depending on how tight the screw is in.
*As noted in a comment by Greg Hill. Thanks!
  • Some call the Z-shape screwdriver an "offset screwdriver."
    – Greg Hill
    Nov 10, 2020 at 16:30
  • @GregHill, see edit. ;)
    Nov 10, 2020 at 16:40
