I am changing the old analog thermostats around my home with new "smart" thermostats. More specifically, I am installing some Sinope TH1124ZB thermostats. Everything was going swimmingly until I popped open my bathroom thermostat to find the 2 wire thermostat connected to 3 wires in the wall. I don't know the proper terms, but the thermostat red wire was connected to 2 black wires from the wall, and the black thermostat wire was connected to another black wire coming from the wall.
I assumed that the extra 3rd wire controlled the fan for the heater in the bathroom. When I turned up knob in the old thermostat, a fan would turn on. I think I have a fan forced convecting baseboard heater in the bathroom.
Is it safe to replicate this connection with my new thermostat? The very sparse installation guide only shows how to replace existing 2 wire thermostats connecting to 2 wires, and I can't find the right search terms to google to find an example with 2-wire single pole thermostats connecting to 3 wires.
    It looks like the thermostat itself still only has two wires going into it, though? Where does the twisted black pair go?
    – SiHa
    Nov 10, 2020 at 8:21
The thermostat is really just a switch that opens and closes (that is, turns power on and turns power off) when the temperature changes. The wiring in your picture would likely indicate one supply switching what ever is downstream on two wires. That's consistent with your setup, where it's set to switch the heater and the fan together.
It's important that the thermostat be rated for the current and power use of the loads that it switches. You'd want to be very careful that your new thermostat can handle at least as much as the one you're replacing (assuming the original was sized correctly).
But if the switching the two devices was OK before, it should be OK with the new thermostat installed - it's a simple two wire device and although the logic controlling it may be more sophisticated it, ultimately it's function is exactly the same: it's opening and closing a switch.
It doesn't matter which of the two black wires from the thermostat you connect to the single wire, and which to the other two. The important thing is you keep the two that are under the tan wire nut with the red lead from the old thermostat together.
    Thanks, reading this gave me the courage to just go ahead and install the new thermostat just like how the old one was installed. I suspected that it should work since I was replacing a 2-wire thermostat with another 2-wire thermostat. It is up and running, with the fan working and everything!
    – ialm
    Nov 11, 2020 at 6:17
I couldn't get the installation instructions to download without installing an app, frankly you're going to have a hard time getting good advice here with such awful product support. All I could see is it said it was just a two-wire non-polarized connection.
Assuming you are in the U.S. I think you have one leg switching of a two leg 240v circuit because I see three red wires under a wire connector. The red that is part of the cable that has the black connected to the black from the thermostat is part of the hot cable, a second red is part of a cable to the heater, and the third cable goes to the fan. These reds feed one leg hot at all times to the heater and fan, and the blacks are switched to the heater and fan. This guess seems likely because normally most electricians will connect the black from the stat to the hot, and the red to the loads, and you have two wires connected to the thermostat red, so two loads.
You somehow need to verify that the new thermostat will work switching one leg of a hot circuit. If it does you simply need to attach the two wires from the new stat to the same two wires the old stat is connected to.
