enter image description hereI cant get this lever off to take the face plate off. I took off the screw behind the lever but still won’t come off.
  • Do you mean the "lever"? You wrote "leveler" twice. Once that screw is out (or loose enough) the lever should pull off.
    Commented Nov 10, 2020 at 3:55
  • Yes I meant Lever. I took the screw out and it did not loosen the lever.
    – Adam H
    Commented Nov 10, 2020 at 4:41
