Recently I completed my concrete floor done inside my house. But that doesn't look good all the way. I don't want to do tiling, Because i feel that costly. So I planned to do acid staining so that might gives glossy & good looks.
I was looking around for available Acid Stain in Bangladesh. But Unfortunately there's no available products at all! So I was thinking to made a own version of Acid Stain to use on my floors.
I need help on that how to make a Concrete Acid Stain. What formula needed and how to deal with it. I'm complete noobs on these things.
NB: We need the flooring to get as much cheaper way possible
Below I attached sample of my floor currently done.
Current Floor Current Floor Looks
  • i think that you are wrong about using acid stain to make the floor glossy ... acid removes gloss from concrete – jsotola Nov 9 '20 at 4:03
  • Floor paint? Some good products available but need good preparation. – Solar Mike Nov 9 '20 at 6:27
  • In my limited experience, acid would give the floor a very dull look. When you see photos of beautiful acid-stained concrete, usually there is a sealer applied after the stain. It is the sealer that gives the glossy, wet look. Some sealers are expensive. I wonder if a floor wax could be a less costly substitute. – Greg Hill Nov 9 '20 at 17:20
  • @GregHill Thank you so much for your advise & and all of you. I really Wish to improve my floor. appreciate any DIY Idea. – Code Cooker Nov 10 '20 at 1:30
