How do I determine what seat will fit this toilet and are colored seats available?
Inside the tank are these numbers: 1459 388 M59 Aug26
Thank you.
view 2
view 1
Toilet seats are available in a variety of colors and materials, plastic, wood, padded. There are dozens if not hundreds of options.
Your toilet appears? to have an elongated bowl, as opposed to a standard bowl, so you need to make sure you get an elongated seat.
Most seats are universal fit, except for some custom toilets, so you should be able to buy an elongated seat, or a standard, in a color you like. Just two bolts at the back of the seat go though two corresponding holes in the bowl.
You can get soft close hinges to keep it from slamming down.
Example seat.
Vintage Bermuda Coral Toilet American Standard Compton 4043 Pink Retro One Flush
OR
Mid century "Standard" toilet, Pink
That's right, i have nothing better to do then spend time looking at 50 year old pink toilets on the intertubes. ;)-
  • I was hoping to identify the American Standard replacement in the same color as the original. I thought that would give me the correct color. Choosing a color on the web is hit and miss. To get the exact color for my fixture, I thought I would need the model and part number.
    – Yehuda_NYC
    Nov 8, 2020 at 22:20
    Don't limit yourself to the exact color. (a) colors change over the years, so it may not be available anyway, (b) by being flexible on color, you open up many more possibilities for padded, slow-close hinges, etc. Nov 8, 2020 at 22:22
    Contact American Standard directly @ americanstandard-us.com/parts-support/contact-us That is an old toilet, an exact match may not be possible.
    – Alaska Man
    Nov 8, 2020 at 22:23
    @Yehuda_NYC "I was hoping to identify the American Standard replacement" That is not how the question was worded. The question was, "How do I determine what seat will fit this toilet and are colored seats available?" If you want to change the question then use the edit button to add the correct wording BUT shopping questions are off topic here and it is unlikely someone is going to want do your research for you.
    – Alaska Man
    Nov 8, 2020 at 22:29
  • The question as originally asked was more general. Perhaps I should leave it and post a new question.
    – Yehuda_NYC
    Nov 8, 2020 at 22:35
Most toilets in the USA use one of two sizes, and have for many years even as the water usage and tank size have changed. Measure the existing seat at its widest and distance from mounting holes to front and you should find an easy match in any hardware store.
Once you know the type, you can find what colors, finishes, materials, hinges etc. are available.
