My phone/dsl system was installed with a CAT5e cable run to a central blue electrical box. The feed line was there connected to the four other cables that ran to the jacks in the house by crimping them all together with wire connectors.
I assume this was done by the builder or maybe Centurylink at some point. House was built in 2006.
I want to know if this is a reasonable practice to wire the rest of my basement or if there's a better way to connect the jacks to the utility box outside (patch panel or...)
I understand that I'm only going to be using one of these connections to hook up my router, but I wonder if the other wires that are not being used will cause any significant interference or problems with my internet connection.
It would be ideal to run a single cable to my modem location, but I want to maintain the flexibility of being able to put he router in different rooms and I want to keep the land line option intact.
Thank you
