This is a recurring problem I have: Instead of a traditional, straight plug, I have devices with a three-prong plug that lays flush against a wall and angled at 45 degrees. I find these types of plugs quite annoying because they only work if the electrical socket is in exactly the right orientation.
So, I need a way "straighten" out the plug. What would be perfect is something that rotates 360 degrees, similar to these extension cords, but without the cord: https://www.amazon.com/Nekteck-Listed-Extension-Degree-Rotating/dp/B071KSM5DQ
Any ideas?
