I think a harsh chemical remove the varnish on this table, how should I go about fixing it?
    I'd suggest you check out the [finishing] tag at Woodworking. There is a lot of info there. So much so that if you asked to get this migrated over there, it would probably be closed as a dupe. – FreeMan Nov 7 '20 at 15:21
  • The elephant in the room is ---- The Floor OR the DIY play land box on the table ? – Alaska Man Nov 7 '20 at 17:58
  • There is probably no solution other than to cover it with paint or sand the surface down, re-stain, and apply a new coat of varnish. – jwh20 Nov 7 '20 at 19:04
  • It will take a refinishing of one sort or another, whether a re-amalgamation or stripping and refinishing with a compatible finish to match the original. I am sure the problem is with the finish, not into the wood. It may be a simple as a water stain if the finish is shellac or lacquer. – Jack Nov 8 '20 at 1:39
  • yup looks is unavoidable, is an easy DIY job? – seesee Nov 8 '20 at 16:27
