After several weeks of the interconnected smoke alarms, I have had two momentary false alarms. I am yet to figure out why or what is causing this. Strangely they have both occurred at night causing me go down to the basement and cellar to investigate.
Question: If the interconnect wire is run in a conduit with a high amperage wire could a low voltage be induced into it causing the alarm to trigger?
  • Probably, usually there are regulations about wire spacing between signal wires and current / voltage wires.
    – Solar Mike
    Commented Nov 7, 2020 at 6:18
  • What does "After several weeks of the interconnected smoke alarms" mean? Did you just recently move into a place with hard-wired alarms and you're getting false alarms? Did they recently get installed? Have you just had the false alarms over the last several weeks?
    Commented Nov 7, 2020 at 15:32
  • I recently installed 5 alarms and interconnected them. No false alarms for weeks then two in a week.
    – Sean
    Commented Nov 8, 2020 at 11:53
  • Can excessive heat in a room trigger a smoke alarm? My cellar is locked up all day and it gets quite hot. Im in the process of installing an exhaust fan.
    – Sean
    Commented Apr 8, 2021 at 23:45
