I'm using this Diaphragm Pump that I bought online for a certain project, and I want to attach the inlet and outlets of this diaphragm pump to a PVC pipe.
I think that Barb Outlets are supposed to be used with quick connectors to hoses, but I really need this pump to be used and connected with a PVC pipe.
I searched online and I can't find a quick connect pvc coupling pipe fitting.
Is there such thing as a quick connect pvc coupling pipe fitting? and if there is, is there a correct way to call it?
If there is no such thing as a quick connect pvc coupling pipe fitting, what is the best way I can do to attach the inlet and outlet to a 1/2 inch PVC pipe and not have leaks?
All suggestions and corrections are highly appreciated.
