Above is a picture of the wall adjoining the bottom of the staircase leading to the basement.
I am finishing my basement (in the process of flooring/molding etc.). I intend to use baseboard, then quarter round after the flooring. The builder has left the portion of drywall as in picture.
What are my options to finish this so I can paint/apply baseboard, etc.?
  • If you're installing baseboards you can do that after the floor. Then you won't need quarter-round. Quarter-round flooring trim is a shortcut to avoid removing baseboards. Since you haven't got any baseboards yet, and you plan on adding them, you don't need the quarter-round. Nov 4 '20 at 21:36
I would cut a thin strip of drywall to fit that missing section. It will be a little awkward because it's thin and long and therefore easily breakable. Cut it from a piece that has a finished edge to help hold it together. That edge should face the door frame. Because it's so narrow the best way to fasten it in place will be with construction adhesive. You may have to support the strip from behind to get the strip level with the existing drywall. Scrap cardboard should do the trick.
When mounting the strip pack some spackle between the strip and the drywall. The reason you want to do this is because the repair will be too narrow to tape and the packing will help keep the spackle from cracking.
Smooth any excess spackling and hold the strip in place for a few minutes to let the adhesive set.
You can then finish the job with additional spackling and sanding as needed after the adhesive has set firmly.
That looks very much like there had been some baseboard there that either wrapped around the wall and returned into that gap, or perhaps there was trim on the stair stringer that wrapped into that gap.
I'd suggest that the easiest way would be to replace that with a new piece of baseboard that will fill the gap. Of course, this means that your new baseboard would have to be this tall.
Another option would be to put a small piece of wood in that spot to "widen" the apparent width of the stair stringer. It's hard to tell from the image provided whether the stringer (and quarter round above it) sticks out beyond the wall board, or if they're flush.
If they're flush, simply put in a small piece of wood that matches the height. Don't install it with the end-grain showing - it will split far too easily when you try to nail it. Instead, install it with the end-grain out, and drill pilot holes for the finish nails to go through.
If they're not flush, install a piece of the baseboard trim running uphill with the stringer, and a piece horizontally with the drywall. This will likely fill most, if not all, of the gap.
  • Thank you. My baseboard is not as tall. Actually the sheet rock sticks out. Also, it does not stick out uniformly.
    – souser
    Nov 5 '20 at 15:30
  • I'm not sure how "not uniformly" it may be, but this sounds like a great opportunity to fix the issue with the drywall being proud of the stringer. Extend the stringer, maybe put a decorative wood bead of some sort up that edge to cover the gap and run all the way to the ceiling. Just some thoughts.
    Nov 5 '20 at 15:59
Nail a piece of 3/4 tall enough to meet stair base, but use a jig saw to drop it down to 5 1/4 or whatever your base is. Cap it accordingly with 1/4 using 45's to match the custom base, and reverse 45 to do a corner for the 1/4 cap on stairs, sand it to match the shape - If you don't plan on using a cap on your baseboard, then back 45 it at the left corner to kill the look in a finished lookenter image description here
