It has been recommended by a building surveyor that will install another airbrick in the external wall of our Victorian house to help with airflow in the sub floor.
I have seen multiple examples online of how to install a new airbrick on a modern brick house but not on a house made of stone where the stone are much harder and of uneven size. I wonder what the best tool for the job would be and the best approach to drill the rectangular space and correctly bed the airbrick?
    Assuming (since I'm not familiar with the term) that an airbrick is a brick with air holes, I would think that simply drilling holes of whatever size those are directly in the wall would be much simpler than making a square hole to mortar a brick into. – Ecnerwal Oct 30 '20 at 14:17
  • Yes it is - most old houses with a subfloor have them installed. Not sure it would be recommended to just drill holes in the stonework but I might be wrong – AWGIS Oct 30 '20 at 14:24
  • @AWGIS It's not just old houses; it's required by code for any construction with a crawlspace foundation to be breathable in this manner. But there's nothing wrong with Ecnerwal's solution. It's way simpler and cheaper (assuming you have or can rent/borrow an appropriate drill & bit) to just 'convert' a normal brick into an airbrick. Just be sure to cover it with a grate on one or both sides so that critters don't use it as a door into a new spacious hotel :-) – TylerH Oct 30 '20 at 15:28
  • Thanks for your answers - I didn't really think of the option to just drill holes. In an ideal world I would prefer to fit a proper vent to be in keeping with the rest of the airbricks. I have also read examples where the drilled holes have slowly degraded or blocked themselves up with salt growth – AWGIS Oct 30 '20 at 16:18
