I want to mark the ground with spray paint and wooden stakes in a nice 25 ft radius circle. The simple way would be to drive a narrow stake in the ground at the center point, tie a 25 ft string to it, and drive the stakes anywhere the string is pulled out.
The problem is, I don't have access to the middle point currently...there are some big rocks there. I do have access to the areas where I will be drawing the spray paint though and quite a bit of space around.
Is there some other simple means of drawing the circle, without having access to the center?
No, center point isn't accessible...there is stuff in the way...I'm going to move that stuff later, when I can rent the equipment.
I'd prefer the circle be fairly accurate, about as accurate I could get had I used a center string...maybe within a 1/4 (?) of accuracy.
10
    Mark out a square then rough in the circle.
    – Solar Mike
    Oct 29 '20 at 17:46
    Draw a template that is 50 ft x 50 ft on paper? Or am I misunderstanding your meaning?
    – Village
    Oct 29 '20 at 17:56
  • 4
    This is why providing as much detail as possible in the original question is important.
    Oct 29 '20 at 18:05
  • 4
    I'm Super curious what you'll be building in this 2000sqft circle (its not germane in any way to your question of helping you draw a circle, just curiosity). Also is the 1/4 foot precision or 1/4" precision (which will be tough with string)...
    – mark f
    Oct 29 '20 at 19:03
  • 4
    Consider that your spray painted line is very likely to be messed up by whatever machinery you're going to "rent later", thus the accuracy of the circle now is somewhat irrelevant. Mark the circle after you clear it or you're wasting time.
    Oct 30 '20 at 11:01
12 Answers 12
15
You don't have a centre point, but you can have a perimeter grid marked.
In its simplest form, the equation of a circle is derived from Pythagoras' theorem.
https://www.mathopenref.com/coordbasiccircle.html
That shows a centre point with + and - coordinates. But if you use tape measures to mark out a square around your rock pile (or a 50 feet line marked at 1 ft intervals) you can then plot the coordinates of the circle from the perimeter square rather than the centre.
So if P is 13,15 on the diagram, you'll count 10 marks down from the top and measure 12 ft in from that point on the right-hand side. Then join the dots. For an even smoother circle, plot one section of circumference (corresponding to approx 1 ft square) even more accurately on a template and move that between the marked dots on the ground. ......
18
If the ground is perfectly level, then you don't need access to the middle of the circle, you just some point directly above it, and then a longer string traces the shape of a cone as you draw your circle.
As you said that you need more precision than having a person just stand on the rocks and hold the string, you will need build some sort of structure to hold the end of your string stable above the rocks.
You could:
  • Use three stiff pieces of wood or pipe to make a tripod that goes over / around the rocks. Tie a loop on one end of your string so it fits around where the three pieces join, and then mark the string where it comes to one edge of your circle
  • If you're going over something that's relatively long, you may want to build two supports on either side, to hold a pole with the string tied to the middle of the pole. But in this case, you'll have some problems where the supports interfere with the string, unless your center pole is larger than the diameter of the circle you're attempting to draw.
In the second case, the pole needs to be really stiff, and the string securely fastened to the pole, or you're not going to end up with a perfect circle.
  • Perfect circle? To what tolerance?
    – Solar Mike
    Oct 29 '20 at 18:38
    @SolarMike : depends on the firmness of the ground, how level it is, how stiff everything is, the type of string used (if it stretches), how you've actually attached the marking device to the string, etc.
    – Joe
    Oct 29 '20 at 19:49
  • 7
    Clever! It would be fairly straight forward to deal with uneven or out-of-level ground by the addition of a laser or water level and a plumb bob. Build the point of the cone as described, but rather than touching the string to ground, bring it down to the plane of the water/laser level and suspend a plumb bob to translate the point down to the surface of the ground. It's easy to see how this modification would enable an arbitrarily flattened cone.. to the point of tracing out a flat circle elevated above the ground!
    – Greg Hill
    Oct 29 '20 at 21:15
13
"Stand back I'm going to try maths" (misquoted from xkcd)
r = 50 cos(θ)
This polar plot defines a circle of radius 25 centred at the point (25,0)
This assumes that you can set up one point "G" 25 feet from the assumed centre of the rocks. Measure the angle θ and calculate r = 50×cos(θ). Measure that distance from the G in the direction of the angle and put a marker "A" down. Repeat for angles between +90 and -90. The pattern of markers will be a circle. You do need an initial point set up, but you only need to estimate one point
Alternately, if you can set up a diameter you can use the theorem that the angle on a diameter is a right angle.
If you have a diameter GD, choose point A so that the angle GAD is a right angle. The points so formed are a semicircle. This doesn't require any calculations, but you do need a diameter of 50 feet to get started. The total length of the rope (GA + AD) will vary around the circle (from barely over 50' near G or D to about 70' directly above the rocks). You'd probably want someone at both G and D to pay-out or pull-in the two lengths until you form the required 90° angle.
    +1 See also Angle inscribed in a semicircle, which includes an animated GIF. It might be worth pointing out that the total length of the rope (GA + AD) will vary around the circle (from barely over 50' near G or D to about 70' directly above the rocks). You'd probably want someone at both G and D to pay-out or pull-in the two lengths until you form the required 90° angle.
    – TripeHound
    Oct 30 '20 at 22:38
9
Approximate solution: Assuming it's a steady pile of rocks on a level field: use the whole pile of rocks as the center point. Take a rope, make it into a loop that has approximately the diameter of your circle (plus a bit extra) and trace out the circle. It won't be perfect, as your pile of rocks most likely doesn't have a perfectly circular cross-section, but practically, I think it would be a good compromise.
(Edit: to make the pile-of-rocks more circular, you can drive poles into the ground surrounding it.)
    That only works if the obstruction is rather circular. If it is (in the extreme case) I-shaped, you would instead be tracing an oval shape.
    – KlaymenDK
    Oct 31 '20 at 13:27
  • @KlaymenDK The extreme case you mention is, in fact, called "The gardeners' Method" for creating an ellipse. So, yes, the PO would be better of wanting a perfect ellipse instead of a perfect circle. (c4dcafe.com/ipb/forums/topic/…)
    – Ideogram
    Nov 1 '20 at 10:29
You could use GPS to do this - set up a series of waypoints on the circle, take a receiver to each waypoint, spray the ground, connect the dots.
There is probably an app you can do that with on a smartphone, does not happen to be one I've had need of.
For increasing levels of precision if a phone proves insufficient, there are fancier grades of GPS units.
  • 5
    this will not work with anything short of a survey grade gps unit.
    – Llaves
    Oct 30 '20 at 3:32
  • For a circle this small, you'd need a way-to-expensive GPS unit. This is not a DIY approach.
    – Mast
    Oct 30 '20 at 9:39
    The question doesn't specify the accuracy required. It certainly could work, to some degree of accuracy. And even a consumer grade unit can probably do pretty well at making a circle. Centering that circle on exactly the right point, stable over time, not so much.
    – Phil Frost
    Oct 30 '20 at 13:38
Assume that one cannot climb on the rocks, e.g., the rocks are too slippery or are dangerously sharp, or it is taboo (thought to displease vindictive local gods), or the Russians have smeared them with Novichok. . . but it is possible and acceptable to pass a line over the rocks without touching them.
Two people take a 50 ft line (or a measuring tape) with a plumb bob hanging from the middle and hold it taut so the plumb bob is just over a spot on the rocks that the two people agree to center the circle on. Each person uses a plumb bob to mark the spot under their end of the rope and drives in a stake. The specified circle is now determined and it just remains to fill it out. It can be filled out with only the measuring tape.
There is a trig formula that gives the length of the sides of a regular polygon inscribed in a circle of a given radius*. For a circle of radius 25 ft this gives:
Number of sides, Length of sides (ft)
4, 35.36
8, 19.13
16, 9.75
32, 4.90
64, 2.45
So to locate the two other vertices of the square use the tape to inscribe two arcs of length 35.36 ft from each of the original two stakes and place two stakes at the two intersection points of the arcs. There are now 4 stakes on the circle.
Next, from each of the four stakes inscribe two arcs of length 19.13 ft which generate 4 intersection points which are on the circle and put a stake at each of the 4. There are now 8 equally spaced stakes on the circle.
Next, from each of these 8 stakes inscribe two arcs of length 9.75 ft which intersect at 8 points on the circle and put a stake at each of the 8. There are now 16 equally spaced stakes on the circle.
Next, from each of these 16 stakes inscribe two arcs of length 4.90 ft which intersect at 16 points on the circle and put a stake in each of the 16. There are now 32 equally spaced stakes on the circle.
And so forth.
*s = sqrt(2) r sqrt(1 - cos(360/n))
    A circle is, after all, nothing more than an infinitely large number of infinitely short straight lines.
    Oct 30 '20 at 10:57
If you have at least a third person to hand (ideally four people), I suggest a variation of Jim Stewart's answer, but without any calculations.
As with Jim's answer, have two people hold a rope/line with a plumb-bob above the desired centre-point. The length of this main line isn't critical: its purpose is not to measure anything but just to maintain the position of the centre (if the two ends can be tied to something solid, or fixed to stakes, you don't need the two people holding it).
Attached to the centre-marker of the main line should be one – or, ideally, two – other lines. These should be 25' long (or be longer with the desired radius of 25' marked on them). Things will probably work better if this/these lines are lighter than the main line (e.g. string).
With only one of these secondary lines, just have someone walk around the perimeter of the intended circle and mark the positions of the posts at 25' from the centre. Care would need to be taken to not "pull" the centre-marker to one side.
With two secondary lines, the fourth person should stand on the opposite side of the circle. As well as being able to mark two posts at a time, they can help prevent the centre-marker of the main-line being pulled out of position.
Alternatively, have three people remain in fixed positions – at roughly 120° from each other – to keep the centre-point in the desired position and just have one person circling with a 25' line/string marking the positions for the stakes.
Take a piece of rope that is at least 2 * pi * 25 = 157.1 ft long. Leave enough at one end to tie a knot, and mark the location that is 157.1 ft from that point.
Lay the rope around the rocks and tie the two ends together at the marked points, so that you have a rope with circumference of 157.1 feet.
If you have helpers, let everyone take a section of the rope and pull it away from the center point as far as possible, then lay it on the ground. If you're working alone, try to simulate that. Adjust between the points of pulling to make the rope follow a circular arc.
You could also use the stakes at this point to taughten the rope; probably some iteration on their positions will be needed.
At this point, if you want it to be more exact, make a 6 to 8 foot template out of plywood with one side that is an arc of 25 ft radius, and use the template to more exactly adjust the rope.
Then spray paint around the rope.
Have a person climb onto the rocks and hold the center point.
It won't be super precise, but should be close enough for the rough estimate I'm guessing you need (since the rocks are still there).
  • Greater precision is needed. Rocks aren't so simple to climb on and get string to.
    – Village
    Oct 29 '20 at 17:56
  • 7
    It takes a village to draw a circle.
    – Alaska Man
    Oct 29 '20 at 18:47
    "Marty - you're not thinking three-dimensionally!" (doc, modified)
    – Criggie
    Oct 30 '20 at 22:32
A practical solution is to mark out sufficient points on the circumference, per one of the geometrical or analytic answers above, then paint your circle using a wooden or board template of an arc of the circle, long enough to accommodate two or three of the points.
You can hence compromise between the number of points you mark out, and the size of the template you use. You can even use a template with a slot to constrain the paint more neatly. I would have thought that more than 10 ft of template is going to be rather unwieldy, this would need around 16 points marked out. A five foot template would need around 32 points pre-marked.
Note that you should have enough space on your to mark up the template using a radius line.
Poster is spray painting the ground..... Use a Template.
Mark a template where you DO have access to the center point. Accurate and no math....
Cutout the Template, on your scribe line.
Move the template where you want. Spray paint the cut edge for a clean crisp line.
Done.
a 25' circle, will only take 6 sheets of 4'x 8' materiel cut into 2'x8' pieces (Lauan,Cardboard,ChipBaord, etc), glue or Stapled together.
25' Circle with 12 2'x8' Segments for pattern
The midpoint of a sliding ladder describes a quarter circle. If you can lay out x and y axes, then a 25-foot ladder (or 25 foot taut string) with the midpoint marked will trace out a circle, a quarter at a time. See
https://mindyourdecisions.com/blog/2019/02/14/can-you-solve-an-oxford-interview-question-the-sliding-ladder-problem/
