I need to wire 2 bedrooms and a living area. Rather than the addition of a separate lighting circuit with wires going everywhere above, I plan to run each room on a separate 20amp circuit (12/2) with shared receptacles and lights.
Starting my home run from outlet to outlet then simply T-ing off an outlet where a switch would be located above, I could run power to the switch, then to the light. Now back at the T junction, power would continue down the line of outlets finishing till the end of the circuit. My wiring would be in parallel, so pig tails on everything, also would be using a deep enough box to house the 3 sets of wires coming into the T junction outlet box(power in, power out, power to switch and pigtails to power outlet). Is there anything wrong or against code with this method of wiring??
I am aware that most people run separate lighting circuit, mostly for the sake of not losing light if a breaker flips, but for me that does not out weigh a simple branch off an outlet for ease of install and less wire to run, less connections, less potential hazards. In my mind it makes sense and is efficient. Am I missing anything? What do you guys think? any info would be much appreciated.
