My security camera is mounted under my garage's overhang (the Ethernet run originally installed by a Tech). After i installed my security camera and moved the wires around, I was having trouble getting the two pieces of soffit where the wire was initially coming through to overlap and click together. I stuck all the wires on the inside and know only a microphone and one Ethernet wire go out to the camera.
There is no real appreciable gap, but I figure these things are supposed to overlap for a reason. Is it okay as is, or do I need to get up there and keep fighting and rearranging to ensure they actually click fully together? see photos:
showing attempt to close with pry tool
showing end result how i left it
    If you don't snap these together then that will leave an easy entry point for critters. Yes, it can be a real pain to get these to join in the middle like this but it can be done.
    – jwh20
    Oct 26, 2020 at 17:25
  • that makes sense, i'll try again next dry warmer day. Before the wires came out in the middle so there was a gap there. In the meantime do you think its okay if i apply some white electrical tape there? When we're talking criters, you mean rodents not bugs? like a rodent may be able to wedge his way in?
    – HelpEric
    Oct 27, 2020 at 1:17
  • By "critters" I was specifically thinking of rodents not insects.
    – jwh20
    Oct 27, 2020 at 10:25
