Hoping for some help here. I have a 3 way dimmer switch running to a fan/light combo that I have jumped a single pole switch off of to power a new exterior light. There are two 3 way switches on the fan/light combo and I have source power coming into the box which ran through the 3 way to the fan/light combo which I jumped off of. I pigtailed the hot off the source and ran one to the 3 way and one to the single pole switch and tied together the neutrals.
The issues I am having are:
When the fan/light combo is off and the exterior light is on, one of the 4 lights on the fan is on with low power. Also, when I pull the chain and shut off the fan light, the exterior light goes off.
When both the fan/light combo and exterior light are on, all is good.
Both 3 way switches are wired correctly, though I haven’t been in the fan yet (hoping to fix without opening up the fan connections since the wife wants a new one and I can’t justify taking it down and putting the old one back up).
What is the issue here? Issue with the 3 way dimmer, issue in the fan, the “source” is something different altogether?
From a comment:
So ironically, In digging further, it seems my source into the box has the line power on the white wire and neutral on the black wire. One thing I am confused about though ... it appears the hot travels up the fan/light and neutral connects to the common on the 3 way switch ... fan/light and 3 ways work as intended with the setup but that wiring doesn’t seem right. For the new light ... as long as I tie the neutral to the black source wire and the hot side to the white source wire, I should be good right?
