I'm debating how wire will be run in my workshop. I asked a similar question earlier, but this deals specifically with working with conduit.
First off, I think I prefer running raceway along the walls. However, I'm considering metallic conduit as a alternative. If I run conduit, how would I go about adding another outlet (or something) in the middle of the conduit run? Do I have to disconnect everything downstream from where I want the addition, pull the wire out of the conduit then cut the conduit, add the new receptacle and pull the wire back down the conduit to the downstream receptacles? This seems like an overly laborious effort just to add "something" else to the current conduit, but I see no way of cutting the conduit without pulling the wires.
