I need to add a privacy latch on this side of this interior door. (Photo #1)
I looked through an extensive set of latches at a local hardware store and none of them had the right strike plate or receiver for this situation Except for a sliding barrel bolt, which I don't want because they tend to slide when not wanted and will eventually bash into the door frame.
Nearby (Photo #2) I used a barrel bolt but there I embedded the receiver behind new trim, not an option for the door in photo #1.
What is a workable latch for this type of situation, something that stays out of the way when not needed?
