I'm looking for the name of the plastic piece that is labeled #2 in the attached picture.
The condensate goes into the plastic box and then overflows into a tube that goes to the sump.
I'm having the hardest time finding the name of the piece.
    What is the model number for your furnace? That part is a specialty part for your furnace, not a common everyday part. Get with the manufacturer for the information.
    – JACK
    Oct 20 '20 at 14:59
    What problem are you trying to solve?
    Oct 20 '20 at 18:51
  • Does the furnace have name? make and model? have you looked in the manual, have you searched the intertubes for a manual/parts list? Why do you need to know its name. (What isherwood said). Guess based on info provided. - Condensate pump cover for X brand/model of High efficiency furnace*.
    – Alaska Man
    Oct 20 '20 at 18:55
To me your parts names are:
  1. condensate pump
  2. condensate drain assembly
  3. discharge hose for condensate pump
The drain assembly is different than the ones I have used and in some cases I don’t use OEM parts because of the cost when a standard off the shelf part can be made or purchased for much less.
It is a condensate drain trap.
