I have a bullnose corner with roughly 3" hole. What is a good way to fill such a hole and repair? Can drywall patch be applied? Or some other method? Do I need mud or just spackling?
  • use spackle to fill the hole ... stuff some paper down below the hole to keep the spackle from going down ... drive a couple of screws partially into the corner wood inside the hole ... leave them sticking out inside the hole, so that the spackle anchors to them – jsotola Oct 18 '20 at 2:16
  • Use just enough spackle to fill the void and shape the curve. That will leave you less area to try and match the texture and paint. – JACK Oct 18 '20 at 2:44
  • texture paint is a nightmare for repairs, I see a previous repair at 5-O'clock from the current damage. – Jasen Oct 18 '20 at 7:41
