I'm replacing the copper pipes in my house and I'm converting the trunk and branch type to home run style using PEX A pipes. I want to protect the pipes in the wall that I'm running them up from the basement to the two bathrooms upstairs on the second floor. I have a total of 10 pipes going upstairs. First I thought of using metal sheet to wrap around the section of the wall that the pipes are going up. The kind that is used for the ducts, but that was too thin and a regular drywall screw went through it without a problem or me noticing that I punctured the metal. Then my next idea was to use 3/4" electric conduit and run my 1/2" PEX pipes in those. It seems like a good idea, but I'm not sure if that would be against any kind of code and if the hot water pipes would be damaged from friction damage as they expand and contract quite a while as I noticed from the pipes that are fixed between the joists in the basement. My plan was to use plastic rings on each end of the electrical conduit to protect the PEX pipes from getting scratched over time and there is a 90 degree bend in each conduit to allow to easily continue with the pipes in the ceiling wall once it enters that section. I was even thinking of using insulating foam sealant to push into the pipe to not to allow the PEX pipe to move around and get damaged from the friction.
Do you guys think that would work?
Thanks for the suggestions and ideas.
