I just noticed some green corrosion around the shut off valve area under a bathroom sink. This is a new shut off valve that was installed by a plumbing company only around a year ago. Should I have them come out to re do it?
  • is there any indication of a leak at the joint? This level of copper oxidation is often the result of a wet joint or low spot accumulating water drips. – mark f Oct 17 '20 at 14:29
    There is a dried green dot right under this area. My thought is there was maybe a very small drip that caused this build up and now the corrosion has sealed things off perhaps. – user109773 Oct 17 '20 at 15:31
It may simply be condensation on a cold water line. The rule of thumb in plumbing is if the joint isn't leaking don't eff with it.
  • Think of it as a feature of copper alloys. Metal loss would be nearly impossible to measure ( It would require removal and laboratory testing). – blacksmith37 Oct 17 '20 at 16:08
Perhaps excess acid flux was not wiped off. Vigorously wipe the area with a wet paper towel and see if the green deposits come off. If they don't, then rub with a terry cloth rag wetted with hot water. Probably the green will not return.
    Pretty clearly a threaded connection. – Ecnerwal Oct 17 '20 at 16:28
  • I saw signs of threads, but in my (limited) experience all shut-off valves are connected to the house supply by sweated or compression so I decided not to believe my lying eyes. – Jim Stewart Oct 17 '20 at 19:46
