I have a flat pack shelving unit to put together. It has double ended screws. According to the instructions you just screw them in using your hands. This is impossible: the pre-drilled holes seem way too small for the screws. I am unable to screw a nut on to tighten with a spanner as it is two normal screws stuck together not the usual version.
Suggestions, anyone?
